Lb7 injector test help
Nightlb7
175
Maryland
The Bosch remans are $1700 on his receipt not exactly sure where you are seeing them for $800 maybe the referbs? I have not come across anyone that has had a issue with this company before until now but i do appreciate the input here as it will for sure influence future jobs, these have been tested by 2 different places trying to resolve this issue, is there a test that is not being run on these sheets that needs to be done? The reason for asking this is he's at the point we are trying to prove this for a warranty stand point, they say they are good but obviously there's a issue here that needs to be pin pointed so the truck owner can get his situation resolved. He provided these parts and im doing everything I can to help him out, just trying to help out a good guy that's getting the short end of the stick.
Sent from my LG-K540 using Tapatalk
3,591
May I ask who the "two places" are that you've had test them? Did you ask what tests were done on them? I ask b/c those sheets you included are hard to read and get a sense of what was done.
Brent@LDS
651
Wisconsin
I would be careful with the injectors that you have received for $1700, that's as much as I can say. Actually do you have a picture of these OEM Bosch injectors?
Nightlb7
175
Maryland
Injectors direct has tested them and he sent them to another shop that could "test them further" then his machine can, they are in the process of being shipped at the moment so I can't take a picture, is there something about them I should know to look for?
Nightlb7
175
Maryland
Injectors direct and another shop that he sent them to, he sent me copies of both tests I just don't have them with me at the moment I will try and post them up asap, he said they were completely tested through the entire rpm band.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
So the one who supplied the junk injectors was in charge of both tests?????........ Yeah....
If you really want to know why there junk send them to someone reputable like S&S. You already know they are junk. You just need someone to tell you why I guess. He's never going to do that for you.
3,591
Well, there's the problem right there. He doesnt want to warranty them, so he'll tell you anything to make you go away. X2 to what IOWA said.
$799.99 for a set of 8 of there refurbished injectors. They list BOSCH FOR $1699.99, but I bet it's like PENSACOLA'S BOSCH REMAN'S that were failing much like these. There were some posts about 2 years ago over at DP about the supposed BOSCH remans failing right after install. It's one of the reason's you have to be careful who you buy them from.
https://www.injectorsdirect.com/product/lb7-refurbished-fuel-injectors/
Nightlb7
175
Maryland
Yeah I have heard about Pensacola issues but as far as injectors direct I wasn't aware there was a big issue, even a page on here some time ago about them and the majority said they had a good experience with them, not defending them by any means just what I have seen and apparently I missed something lol
