LML Dynoed LML
S Phinney
4,008
Quncy, Fl
I had a chance this weekend to dyno my lml at the Diesel Thunder event in Holt Fl. Dynoed it on Friday and again Saturday to test a couple changes. My goal in the testing wasn't more hp just better torque. I am pretty pleased with the results. They speak for themselves. IMG_0492.JPGIMG_0504.JPG
3,590
Am I seeing 611hp on the first one? Damn Shane, thats just with what's in your signature?
S Phinney
4,008
Quncy, Fl
It is stock turbo and stock injectors. Just a cp3 conversion delete and tranny. It makes good power. If all the tuning parameters where available compared to older generations I could do better. That's on 1500 us and I drive it everyday tow and all on that tune. It's pleasant and fun to drive.
S Phinney
4,008
Quncy, Fl
The bottom right is 736 and 1240
That's with a little laughing gas! First time I have ever tried any and most likely will have a progressive kit on my race truck. We sprayed my sons stock injector lly with a 371 and put down 1046.
WVRigrat05
3,149
41
French Creek, West Virginia
I figured it was but I wasn't sure. The 612 is still impressive for stock air and fuel.
Been googling around and can't find the right key words I guess.. what will a stock trans bolt on Lml make with a hefty max effort tune?
kiwilml
454
I'm assuming you mean with stock cp4? Probably lower 500's if I remember correctly..
S Phinney
4,008
Quncy, Fl
The two variables I would consider are if you have taken care of the pressure with tuning or a dummy g solenoid. The latter I prefer and how it fuels to limit torque. If you look at the dyno sheets you can see average torque being more than 100 ft/lbs lower. I made a couple little tweaks and brought that up as you can tell in the second sheet. Both tunes have the same total fuel at wot with just some minor changes in between. That was pretty big results for the changes that I made.
I was thinking dummy solenoid as it's more consistent. Thanks for the info, Lml is still new to me. I only have a handful I've messed with and they are all lower power.
S Phinney
4,008
Quncy, Fl
Easier to do and you get to service the tranny all for less money than tuning it for pressure.
Slowmax
Build what others' won't
Aug 3, 2013
468
United States
Was a very big Diesel drag racing event this past weekend, at the event you spectated at. With that Dyno number what did it run down the strip? :thumb:
S Phinney
4,008
Quncy, Fl
I did not run it this weekend. I have ran it before on a tune that was not as powerful and trap 83.65 in the eighth. I am pretty sure it would trap at least 86 at 8000 lbs with me in it. I will try it out again pretty soon to see how it runs on the track now.
