Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
Took a drive in my truck together this bad boy. It was 750lbs and a bitch to get out of the truck haha. Rode on the rear bumstops all the way home
picture.php
That is a nice compressor:thumb:
minerigger
2,660
Casper, WY
When I put my exhaust on we put a one inch tack on all the joints. It hasn't come apart/moved and I can always use a cutoff wheel and grind the weld out if/when I need to remove it.
I move shit to much is the issue. I've had the exhaust off totally 2 times and the front pipe off like 10 or more. Hi I'm Brock and I have an addiction to changing things. I will say not as bad as Corbin
1,457
Dang it man you weren't kidding that is horrible. Mine is not that bad, not even close lol
Neither is mine
Got matching wheels on my burban now.. had to raise the front ~1.5" and some trimming
305/70/17 front and 315/70/17 rear for now. Next week have matching rears
Going to flush PS system with some ISO 32 HYD oil on my LMM and need to flush the brake system
NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
got rid of the homobar, and the halo/LED "lights", installed some smoked headlights w/putco led's, and led tail lights. So far im pretty impressed by these leds...wasnt sure after some of the things i was reading. Waiting for my fog light harness and 3rd break light to finish up
Hey I saw that
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
My preggers wife was feeling blue when we were running errands so I left a couple fatties in a parking lot to cheer her up. It worked butttttt now when I turn up an incline my front end goes "pahpop!"
Jan 28, 2015
961
Ohio
Yup, on sale at tractor supply :thumb:
I have the same one. Check the cage on the back and make sure the pulley and belt aren't rubbing it. Also there is a little screw in filter on the back. You will see a square in the cage. Make sure that Is tight. The the line on the top right side and the eye gas. My leaked oil from not being tight enough. Once all that is good to go they are great compressors. I have one at home and my buddy has the same one for his shop that runs 24/7.
