NinjaMax
WTF!
Oct 3, 2012
1,266
Severance, Colorado
Added some new tail/head/marker lights, Hopefully have the 3rd break light on tomorrow and start the factory install for fog lights
. Hope the harness is in there somewhere
1,517
Custom rims arrived while I was out for the burban..
Got 4 loads picked up delivered
Feeding rails
Transformer/Thor's hammer
'14 6105r
And a last minute tool move for a press that has no picture..
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Replaced two of the three exhaust hangers, got a lovely rattle from the exhaust hitting the rear shock so hope this fixes it
Lesson to be had here, never buy a regular steel setup when you live in the northeast. Friggen ball of rust on every clamp :mad:
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
My Magnaflow stainless is rusty too, not a ball of but rusty non the less:thumb:
minerigger
2,660
Casper, WY
I painted my mbrp stainless black and then used antiseize on the joints and on all the threads for clamps...seems to be helping so far but mine was rusting as well. Buddies aluminized is just dirty
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
I will snap a pic of the one clamp later when I replace the last hanger. Its more rust than it is a clamp anymore. Pretty sure the whole exhaust is just rusted together and thats how it seals anymore. :mad:
But, glow plug module should be here this afternoon, and ordered a new key fob finally :thumb:
minerigger
2,660
Casper, WY
I just want a new 5" and a new hanger by the trans. I'll keep my mbrp muffler and tip but not impressed with their exhaust. I need to figure out some stuff this summer when I actually care to work on the truck
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
You are telling me.
I should have learned my lesson the first MBRP piece I got, but nope, went and got their downpipe too :screwy:
minerigger
2,660
Casper, WY
I think mine is mbrp dp as well. It sounds super good but there is just no getting it to fit right or stay tight or vibrate. Stupid front pipe vibrates all the damn time on the torsion bar crossmember.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Pull it all apart and use never seize on all the slip/pipe joints, clamps, all the threaded nuts and bolts. Adjust and evenly tighten them down, after driving for about a week or so recheck all the nuts and bolts.......
minerigger
2,660
Casper, WY
Done that like 4 or 5 times mike. Also have never seize/anti seize at all the joints and nuts/bolts...dp clamps are so tight that any more and they will strip
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Took a drive in my truck together this bad boy. It was 750lbs and a bitch to get out of the truck haha. Rode on the rear bumstops all the way home
picture.php
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
When I put my exhaust on we put a one inch tack on all the joints. It hasn't come apart/moved and I can always use a cutoff wheel and grind the weld out if/when I need to remove it.
