Actual reason for lb7 injector failure
Jul 24, 2013
174
11
jacksonville nc
I know it's been asked before but does anyone have any actual hard evidence as to why the injectors fail so frequently?
Has anyone ever tried sending the internals to an injector off to be coated with some sort of hard coating like tin coating, diamond coating to try and prolong the life of these things?
I got brand new updated Bosch injectors, hp lines and put a lbz cp3 in it all at the same time, all parts except cp3 were from injectors direct 30k miles ago and I have 3 that are crapping out.
I have a air dog 100 with new filters every 6 months, and a cat filter adapter on the engine itself. I RELIGIOUSLY run diesel kleen with 2 stroke oil mixed and try to run 50 cetane diesel from Southern states as much as possible. Now in my mind I should not have to worry about these things crapping out already but they are.
Any hard evidence or reason why this happens?
CarolinaHD
969
NC
Yea gotta buy quality remans from a reputable source then we can talk about why they fail. Yours failed because of where you bought them from.
3,420
There are simply different levels of rebuild quality. As for why they fail, there are a lot of reasons, none of which has ever been concretely proven.
Jul 24, 2013
174
11
jacksonville nc
So you think I got boned from injectors direct?
They were supposed to be brand new updated Bosch injectors not reman or refurbished.
Who is a reputable reman distributor? Exenrgy?
I did not cheap out when I had these things changed or at least I didn't think I was cheaping out.
I would still like to hear about coating the internals for longevity
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Unfortunately there is no such thing as brand new Bosch injectors if they claim OEM. Those have all been gone for a long time. Bosch reman is all you will find nowadays.
The tooling to to reman Bosch injectors is ridiculously expensive so either companies buy from a place that does them or they lie and say they are Bosch reman when they aren't.
5,516
590
Just swap over to lly top end and be done with it, lb7 injectors dont just have 1 single common failure. They have several, that's the problem, lly injectors last much longer and are very easy to swap out...
Jul 24, 2013
174
11
jacksonville nc
Have seriously considered this but very expensive to do
036.6turbo
945
254
I just converted my LB7 to an LBZ, wrecked donor truck was 4K, I sold the bones of it for $1,900.00. Just sold my LB7 and 5 speed Allison for $1,700.00.
Do the math, cheaper than injectors. (If you do the labor yourself)
3,420
LLY has a pretty decent failure rate too. As said earlier, injectors are a wear item. But they are much easier to swap on an LLY.
Jul 24, 2013
174
11
jacksonville nc
What all needed to be swapped? Engine trans, wiringing harness and steering coloum?
OregonDMAX
Apr 28, 2013
3,964
Goodyear, AZ
Look at it this way, lb7 injectors are the cheapest injectors. Have toy looked up a set of lbz injectors... No thanks
S Phinney
4,008
Quncy, Fl
If you do a set of Bosch remans and use Motorsports nozzles they will get a much better result on durability. Nozzle design is the main culprit for failure.
