He used these exact injectors.
Welp there's your problem
I must be the only guy who has good luck with Industrial Injection injectors. I had a set of their 60% overs for 50k miles in my truck, then pulled them out and put them in another truck. They now have about 80k on them, still work fine. Heck, I went through a set of Exergy 100% during that same time period...Welp there's your problem
Sent from my FlashScan V2
Some people have better luck than others.. I had a set of 45% industrials last 20k and hazed so bad you couldn't drive the truck.
My original set has 136,000 miles it's a first gen 2004 6.6 Lb7 the second gen didn't have the problems. Mine smoked at idle for two years now and when you first stop badly then clears a bit. On the highway no smoke. How can you tell which one is bad?
Sent from my Pixel XL using Tapatalk
