1,514
Adding redundancy.. oil change, diff fluid change, grease
1,514
What are these two modules do?
I disconnected the big on and brake gauge in the DIC went flat line... guessing it's IBC crap related...
The integrated brake controller is junk on this truck..
The big one is in the way more so than the little one.
Pulled the turbo off the lb7 that's getting my 369 last night.. Side by side comparison
Forever, because he can't ever make up his mind :D
Not my truck the 369 is going on.. Customers.. Gotta have it done by this weekend for him. I've got all the old parts off and just gotta run oil lines and weld the intake tube up.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Oh no problem then, only your own stuff do you change you mind a bajillion times :D
Hernpj01
On a Time Out
Sep 23, 2014
403
Indiana
Cleaned up the fleet. Getting the puller ready to put away for the year. Put forces on the lml for a few weeks and wired the new mirrors up.
mac2881994
47
Put the new shoes on yesterday. 305/50 x20 Toyo Proxy ST2s on 20x10 Fuel Hostages.
Before
After
Troysalm71
286
Bemidji, MN
Egr cooler
Replaced egr cooler after my friends buddy decided not to delete. Me being the smaller guy took in the task went well haha. 4 hour job done in half that time.
1,514
So quick fuel technology pump #2 lasted 600 miles tops and wouldn't pump.. same thing that happened to QFT pump #1
So swapped out it via warranty and forked over another $40.00 or so for an aeromotive SS #11203 pump.. need to redo my pump bypass plumbing
Dumb question.. Why don't you just run a fass or something? They seem to have a hell of alot less problems than those cheaper pumps
8,241
Do you not have a return on the system? Dead heading them clearly ain't working lol
1,514
Had a airdog. Burn up on me.
Fass pump only is $450.00 whole thing is ~600.00 range.
I'm still less than $400.00 into my fuel supply..as One failed I warranty then applied towards better pump..
With exception of the air dog raptor pretty much ate that $250.00
plus I have substantially longer service interval than a similar fass setup.. and easier to bypass if failed while still maintaining filtration
