5,101
703
My cat filters start getting restrictive at 20k, but we don't get fuel the same places as Adam I bet.
1,514
Why I put a fuel pressure gauge on.. between cp3 and filter... Normal does ~15psi at idle.. have gotten fuel that pulled it to about 6psi, in which I P0087 on long grades.
From dyno pulls with fresh filters.. lift pump pressure drops 5-6psi at WOT
Lift pump it a raptor 160gph.
As for fill ups. 95% is at national chain truck stops.. most places see 1-2 trucks dropping/delivering fuel a day
Mine is between the cp3 and filter also and I see a steady 7psi at idle. That's going through both FASS filters and a CAT.
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Raised the bumper and tossed the 1500 grille on mine on Sunday. Still can't get the damn bumper level side to side, but rain put an end to my tinkering.
minerigger
2,660
Casper, WY
Made these
Look like this
3,589
Veryyyyyy interesting Brock! :thumb:
I started replacing fuel lines yesterday. Fronts were "easy"....cut at old braided by trans, unclip the lines, detach from engine, done.
Rear section, well.....not so much. Every quick-connect fitting is full of rusted metal from the fuel line. The little tab tools can't do their job.
8,236
I moved mine out of the garage. Put new garage door springs on. Then backed her back in.
I really should put my new injectors in :D
