UGAfsuFAN
Sep 29, 2015
57
Between VA Beach & Tallahassee
Weather finally cooperated so I got a chance to put new front & rear rotors and pads on the truck. OEM lasted 118k. Went back with the same. As I was lowering the rear end back off the jack stands my jack folded over. Truck didn't really fall down. It more or less shifted to the right about 6 inches and came down gently. Jack is toast but that's alright. Glad I was working on the truck and not my wife's Accord. That one might have hurt a little.
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Hood from donor truck was slightly off color wise to drive me nuts and or had been through hell with scratches etc. sooo, this is why you never listen to friends. :rofl:
Gotta get through winter and a wedding then I will prob spray the front of truck :woott:
I actually kinda dig that lol.. Wrap or hydro dip?
lts1ow
Needs moar PAH!
May 14, 2012
1,598
NJ
Just some 3M wrap, was a gamble since it was not the normal vendor but came out pretty well. We goofed on the front area and you can see the distortion from stretching it too much. :eek:
5,088
683
I kind of dig it too. Now just do the flairs and maybe something else...emblems....
Now that you said it I do see the distortion. I would have to fix that if it looks worse in person.
Burn Down
Hotrodder
Sep 14, 2008
7,092
Boise Idaho
It looks like a black and white movie threw up on your hood Matt:D:hug:
1,456
Well.my A-B vehicle is moving, haven't washed it.
Replaced flex plate.. found reverse doesn't work enough to move it's own weight.. pretty sure the low/reverse band or servo piston is messed up, as all the forward gears work..transmission is a 4l80.. supposed to have a transmission done 20k ago.. got 251k on the clock..
Moves fairly decent with 3.73 gears and 35" tires.. look pretty good if I got 35" all around.... 2wd though
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Got tires and rims mounted up, cognito tube style a arms, new moog pitman, kryptonite tie rods, new 5100's all the way around including steering stabilizer and an alignment big difference from the 37's but I like it :)
Old
New
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
Looks good I actually like those wheels, what are they?
Only thing I dont like is the ugly liftpump filters hanging off the frame. Shoulda mounted on the inside of the frame :thumb:
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Yea I had a friend install it for me since I'm overseas when I get home in November I'm gonna mount it back where the spare tire used to be and install a sump. It's loud where it's at.
Still have a lot I want to do to it going to lower the back some new light housings all the way around and a new front bumper prob to a move? Think that's the name it's all cut I just have to weld it. Also plan on repainting it but after getting the rims on it I am liking the color with them so may just redo same color.
Rims are 20x10 American Force Burnout SS8's with 305/55 BFG's :thumb:
minerigger
2,660
Casper, WY
Got new tires from treaddepot last week and picked up a set of h2s a few months back and finally got them from josh154. Got them mounted monday. Hoping to install this weekend and do a rear axle seal. New setup will be 285/70/17 toyo at2 on h2s. Old is 265/75/16 toyo at on pyo...tires are 9 years old
