5,516
590
Can't believe some people go YEARS without changing fuel filters...
I've got 50k on my lml factory filter. It has had an airdog on it since day one and I change those filters every 15 or 20. Fuel filter life never really moves and rail pressure is perfect. I have cut them open before and they looked great, you only really need them when you need them, lol, the rest of the time filters are mainly insurance...
66lilly
Jun 7, 2014
137
Colorado
&quot;OFFICIAL&quot; What did you do to your D-Max today?
Ya I'm just sort of on the mentality of I'd rather spend $50 on filters every 10-15k miles than spend $3000-$3500 on injectors
5,088
683
Prematurely replacing fuel filters doesn't mean your injectors are going to last any longer. Filters filter better as they load up with debris and you have the possibility injecting debris into the fuel system while changing the filters. Really it's splitting hairs so do whatever makes you feel good.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
I have a cat filter in the stock location that's been there for a while:D. The airdog on the other hand gets changed once a year.
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Just install a gauge under the hood and take a note of the baseline when you install new ones. This picture is taken while the truck is not running and check every so often when I fill up with the engine running. I would not leave a fuel filter installed for more than 2 years.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
I drove it around trying to find oil for it.
One store was sold out (they checked 5 other locations that were sold out too) then I found one gallon each at two locations of another store (I had a half gallon left from the last oil change).
02greysixer
1,829
North Central FL
Put the green truck to work picking up me and the old man's newest project. She did alright, got warm trying to hold 65mph on the hills and set a low rail code a few times. Probably would have been fine if I hadn't left it on a 2400us tune .
Is that an old international?? That thing is tits
02greysixer
1,829
North Central FL
Yeah 67 1100B 4x4. It's complete and very original. Thinking we'll do a frame and drivetrain swap with a slightly more modern 8 lug Ford or gm frame/axles/engine and trans. Kind of leaning toward a 7.3 idi Ford donor. Since it'd still sort of be International. Small lift and 37x12.50 mud grips.
That'd be sweet
02greysixer
1,829
North Central FL
Ficm took a crap last night. Dropped one injector bank then the second bank and shut off. No start and circuit codes for all injectors. Plugged in an lb7 one I had laying around. It wouldn't start with that either but I don't have codes. Hopefully I can find a ficm locally today
