5,516
590
05 green ecsb Silverado LS 4x4. I got a decent deal on it because the bed is beat up and he said it needed #2 & 7 injectors because it runs bad after a few minutes. I drove it a mile up the road, pulled over and ice picked the connectors then drove it an hour and a half home with no issues
Sweet...:happy2:
3,589
I went cable less today. My straps for the tailgate showed up today.
13-ish years later and people are still buying the old VR Straps?? No kidding? My goodness. Rick should be proud that he made a product with such longevity.
Who makes those, and do they come with warning labels.? Because, ya know, here in 'Merica we need labels for those that are too stupid to live.......:rofl:
In all seriousness where did you purchase them at.?
Mike, you're kidding --right? :roflmao:
Pays to have been on the forums all these years, hasn't it? :thumb:
moneypitt
MFNG
Jan 1, 2014
182
WA
Upgraded to 19.5s
02greysixer
1,829
North Central FL
It is very strange to think how much buying a worn out lb7 and joining this forum has influenced my life. If I hadn't bought that pile I'd have never learned enough to get my first mechanic job let alone the job I have now with Caterpillar.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,563
89
LA
Glad to see you back in a duramax man
Sent from my SAMSUNG-SM-G930A using Tapatalk
1,514
Last week went to NC took some state routes came down and stupid steep winding grade... Well got the powwr steering fluid nice and hot... Smelles slightly burnt brakes became really spungy at the bottom.. found a pull off about 3 miles after the hill backside of the power steering pump was 190° surface temp.... Im sure iy was alot higher coming down the grade.
So i plumbed in a 18,000lb tranny cooler
http://www.jegs.com/i/JEGS-Performance-Products/555/60380/10002/-1
Amd flushed with some new synthetic atf
Should help keep fluid cooler since there is not PS fluid cooler on these trucks
chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Waly's in Riverdale UT.
Oh yeah cooler on PS does wonders. Was getting a weird noise turn left from a stop. Since adding cooler no more.
Assembled more of the 7 last night.. Still a long way to go..
1,514
This is a melted 40A relay. I have 3 like this.. said relays are used to control my aux oil cooler fans.. and controlled by switchable ground.
they fans pull ~25A each after startup
And have a relay per fan.
Im running 8g wire with a 30A breaker 8" from battery
Relays are 12" wire lenght from fans.
Right now im Pretty sure going to full blown starter style solenoid
Like such
http://www.jegs.com/i/Taylor/895/383480/10002/-1
Relay im running or was
http://www.jegs.com/i/JEGS-Performance-Products/555/10556/10002/-1
matt78
Finally boosted launches
Sep 10, 2012
924
texas
Sent from my Nexus 5X using Tapatalk
