chevor
Highway hauler.
Sep 17, 2015
192
On the Road
Took over 500 pounds of gear out of back of truck. Hitches, tools, extra fluids. Considering retiring the 2010 from commercial duty.
Truck is showing CEL at startup. Edge is showing PO401 - EGR insufficient flow, and PO674 - #4 glow plug circuit.
Recently P2155 -injector supply group D circut has showed up a few times. And hauling in 100 degree heat was seeing dreaded PO087 - low rail pressure code.
1,514
Saw a guy on a hotshot fb group on mention he was on the side of the road... ~20 miles from my house. So went drug him off the road and to his hotel..
Lb7_Katie
Lb7 Duramax
Sep 8, 2013
851
31
The boyfriend got his LBZ running! It's been down since I think May last year haha. He loves it already!
Built engine short block from Dan @ PPE
Tuned by Duramax Tuner
Fleece turbo
60% exergys
10mm Cp3 from Exergy
WCFAB install kit
1st start up was last weekend.
https://vimeo.com/175783090
830king
191
Central MN
I put in some led signal bulbs, and tore the steering column apart because I had slopp in between the iss and the steering wheel. I found 2 set screws were loose at the pivot point for the tilt steering. I tightened them and the slopp went away. Now before I put everything back together should I pull the screws out and and put a drop of blue lock tight on them?
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
I would, I find myself using Loctite on the majority of stuff on my truck. Most of bolts from the factory has some sort of thread locker.
Did you find that in thread online about those screws.? I thought I had one saved, just don't remember what I saved under..:confused:
830king
191
Central MN
I know I read something about those screws awhile back Mike, I thought it was a lmm. And yeah I'm leaning towards blue lock tight...
3,589
I went out and looked at my little truck today. Still working on the pass side mount design.
BBT is dying a slow death. :eek::(
rgullett83
1,607
Illinois
I did a full detail in and out.. 8 hrs of my life I will never get back. I now remember why I pay some one else to do this
Eddie_LLY
Colorado
Drove on the stock tone to get emissions tested, fooled them again :D
:roflmao: Do you have a test prep procedure that you need to do? I know LB7's don't have egr reactivation stuff to go through like my LLY will, but I don't know enough about EFI live as I've been trying to educate myself as well as I can before making that leap/pick a tuner etc. to know if there's ecm / tune stuff that needs to be adjusted before going in. Or if you guys with EFI live tuning keep separate stock tunes on your PC and reflash before heading in?
Thanks!
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
I just put it on tune 1 and crossed my fingers. I always pass the snap test, just barely. but i always have a hellofa time trying to convince them the damn truck was made without a cat.
dmax_ty
479
Utah
Looks damn good tho man! I spent a solid 12 hours on mine last weekend. I love doing it, however.
1,514
Had to make this.. engine for some reason was having hard time priming itself.
3"*24" tube 3*2 reducer rubber 3-1.5" pvc with 1.5-1/2" npt holds ~3qts
Rubber reducer doesn't much more that 15psi.. and i couldn't at the time find something to go from 3" to 1/2" that was easily removable to fill the tube.
Engine does 40psi at cranking rpms
