Have you talked to Danville yet?
I meant traction bars or spring clamps? My bud Reece has pulled 1.6 60's with worn out shocks, 20" 420's, & Long traction bars. I can't remember what his tire pressure were but they were low, 25-28 front and 20 ish rear.I let has a djm 3/5 drop and Qa1 shocks on it
Air pressure was high like 40-45 I just assumed since it was when 4x4 that wouldn't matter that much
It does matter, but for what it's worth with a simar suspension setup to you i cut a 1.7 my first pass ever.
There are just so many variables. Altitude, humidity, wind, track prep, track temp, air temp, tire temp, tire pressure and so on.
so many variables here.
that 83 turbine and 1.10 housing is not helping spool up at all
have you gone through the front end and checked for any loose or bent?
what are the shocks set to for the track? dual or single adjsutable?
cal tracs or axle wrap bars on the ass end?
how long have you let the trans learn to the new tunes and WOT shifting?
what size tire are you running?
I am going back to the track on Friday to get some more passes in
I will just air the tires down and give it another shot
Anybody know how to upload any videos I would like to post one up from last weekend see what y'all think
https://youtu.be/aTiBG61KPN4
https://youtu.be/es4d0USJ3gQ
Here's two videos.
I used my brothers account btw
In the first video I left atound 15 psi and it did hop... Could that possible be to much air in my tires
I thought about getting a lock up box but everybody told me that the tcm tune was good enough I'm still on the fence about
And should it smoke more while I am trying to spool it I feel like it just hazes during and then after I launch it fuels hard
