Allison 5sp: Is Anyone Making New Snake Oilers?
3,918
1,076
Neenah, Wisconsin
The G4's are not for sale yet.
10-4, might have to wait until they are then. I'm pretty much out for the rest of the season due to my trans and now I'm going to be getting my injectors gone through so that will probably tie me.
Turns out weddings put a damper on your free cash to play with your pickup.
gmduramax
Shits broke
Jun 12, 2008
4,048
231
Nor cal
If it’s just for cooling and more lubrication couldn’t you just plumb in an auxiliary pump fed off the pan?
onebaddmaxxx
1,212
Cecil County Md
In theory Evans kit will supply cooler fluid since it comes off the return line of the trans line so its been air cooled where as the pressure port feed is probably hotter fluid since its higher pressure. Evan and I have talked about cooler line pressure and he tested it back when i was doing the cooler testing for mishimoto i got him one and he tested pressure and was a fraction of what mainline was.
5,055
Mikes is not main line pressure, its control pressure but evans should be cooler fluid
