Tony couldn't get your CTS to work?
this was a a couple years ago when i was doing my own thing and edge was no help at all...
Ya I am trying to use the edge and that is holding up my tuning...could you get it to turn on at all or was it just turn right off? Even if I had to hard wire in a DSP 5 switch, I just want the extra gauges.this was a a couple years ago when i was doing my own thing and edge was no help at all...
My 01 with the 01887305 OS works perfect with the CTS. Never had a problem.
I Updated my V7.5 software and brought everything up to date, know it is doing this???
Im guessing James?? The stock OS is 15188873 and when I upgraded to the dsp5 OS it is now a 01887305.no, blower motor will turn on, blend doors work, but the a/c will not turn on (meaning it wont even engage the compressor for a split second)
is that a 01 os though blake?
With the changed via the its works with the 02 is and the ctss.:thumb:that would be why. if you took a 02 OS and upgraded it to a dsp5 and tried to make it work in your 01, the edge will give you issues.
