LB7 to LBZ (Wiring)
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
From what I read, there is not much to it. Please feel free to correct anything I may have wrong below, as this is what I have found so far.
On the C100 connector
Body side "C" (BN) needs moved to "N"
Body side "M" (YE) needs moved to "R"
Body side "G" (TN) needs to be moved to "J"
Add a purple wire to "B" for 6spd tap shift, tap into the pink wire on the steering column
Add a wire to "F" for GM LAN (+)- You'll run this wires to the OBD port "6"
Add a wire to "G" for GM LAN (-)- You'll run this wires to the OBD port "14"
C2(in electrical center AKA under hood fuse block):
Move the Orange wire from F4 to A8
The wire you move on C2 is the TCM power.
On the C2 harness under the fuse box, there are two orange wires that need to be moved to match where they were on the LB7. If not the truck will crank/die about 7-10 times before starting.
The lower rad. hose is diff. LB7/LBZ so I cut the two in the center, inserted a 2" SS tube bead rolled on both ends.
The LBZ Intake Heater grid fuse and fuse holder need to be added to the LB7 as well.
It was a pretty simple swap, and I would do it again over LB7 injectors in the truck anyday, lol. Some more needed PN#s below...
Petal PN#15233970
Petal harness PN#15233968
Shift indexer PN#15866124
Shifter PN#15860125
Small pins Male #15326269/19 Female #12191819/8
Large pins Male #15304731/19 Female #15304719/19
** A 6spd. trans needs to be used, or convert your 5spd. to a 6spd.(TCM, NSBU, Internal harness, Valve body) 6spd tap shifter, 6spd cluster, LBZ throttle petal and petal harness. Am I forgeting anything?
picture.php
picture.php
picture.php
picture.php
picture.php
1,619
Thank you for posting this. Henry recently posted the connector diagrams for the C100 in GMSpecs area, too.
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
ripmf666
15,123
14
47
Wentzville Mo
Once I get a better Internet connection driving or at a rest stop on this long boring I 70 I will log in to Gm service info and post the 01-03 to see if there the same.
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
The TCM needs to be powered up as well. On the C2 harness under the fuse box, there are two orange wires that need to be moved to match where they were on the LB7. If not the truck will crank/die about 7-10 times before starting. The lower rad. hose is diff. LB7/LBZ so I cut the two in the center, inserted a 2" SS tube bead rolled on both ends. The LBZ Intake Heater grid fuse and fuse holder need to be added to the LB7 as well. It was a pretty simple swap, and I would do it again over LB7 injectors in the truck anyday, lol. Some more needed PN#s below...
Petal PN#15233970
Shifter PN#15860125
Rhall
Old Skooler
Aug 12, 2006
2,241
40
Texas Y'all
Petal PN#15233970
Shifter PN#15860125
I thought about swapping to lbz stuff this year, but i added it up, and ill probably just keep buying new lb7 injectors. Getting new heads, injectors then sending them to exergy, transmission and some of the other power stuff, injectors will be cheaper. But i will def consider this when i go open driveline. This is a good write up.:thumb:
chrisuns
283
San Antonio, TX
From GMpartsdirect
Petal PN#15233970 $36.85
Petal harness PN#15233968 $38.84
Shift indexer PN#15860124 $56.80
Shifter PN#15860125
$39.03
Fixed the part # on the indexer for you. Also, I added the prices.
chrisuns
283
San Antonio, TX
Russ, is the conversion on an 01-02 LB7 truck or 03-04 LB7 truck???
Thanks for sharing!
03-04 LB7. It's to much of a hassle to transplant an LBZ into an 01-02 truck. The computers talk a different speed and language from one another. You'd pretty much have to change every computer, and rewire a ton of stuff to put a 03-07 engine in to a 01-02. That is why most people don't bother with it. Again it's possible, but way to much headache for what is it worth.
Car RamRod
Right Meow!
Apr 12, 2009
231
Just west of Mobile, AL
From what I read, there is not much to it. Please feel free to correct anything I may have wrong below, as this is what I have found so far. What pins are used on the OBD plug for the GM LAN (+)&(-)? I have not looked for that yet.
Those two do not need to be moved, they are unused
or you can use the gray wire that is already there and tap into it near the guage cluster.
I did this swap and figured I'd pass this on.
Rhall
Old Skooler
Aug 12, 2006
2,241
40
Texas Y'all
It depends on what your doing with it, full time puller/racer you wouldnt have to mess with most of the headache.
nekkidhillbilly
Nov 7, 2011
17
Thanks for sharing!
the lb7 has totally different wiring and bcm ecms etc... to do that swap you would need the complete wiring out of a 03 up truck along with most of its interior electrics to do that
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Not always! I'm wrapping up an LBZ with an HTT 68 in an 02. Using LLY injectors, and driven by the LB7 electronics. I'll do a write up when I finish, and have some free time. But yes, the above is for 03 and later.
emiller3
He's Back
Feb 21, 2009
3,586
lake charles,LA.
So how much of a 06 harness would be needed to work in a 02? Bale conn to fuse box or bale conn to inside of truck? Already have lbz ecm and tcm, and assumeing the bcm would be needed also. Just trying to get a list of all items needed to make this work.
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
Depends Wich way you want to do it. If you run it off the lb7 controls, you don't use any of the newer wiring, ECM, tcm. This thread is for putting an LbZ in an 03 or newer truck.
