Well I've been going back and forth about either having my Allison built or swapping to a zf-6. I think I've decided on the zf swap, I really miss my old lb7/zf truck. I want this to look totally factory so I know I'll need the clutch pedal assembly, anybody have a gm p/n for that? As well as the master and slave, column cover, shifter, and boot. As well as flashing in an lly/zf o.s. I'm alright with taking the cluster apart and covering up the PRND321 somehow. The real questions I haven't found answers too are, the reverse light switch and tranny temp gauge. Is there anyway to hook up the back up lamps to the factory Allison harness? Is there a way to hook up the tranny temp gauge in the Allison cluster to the zf? Not that I'm really concerned with monitoring the trans temp but I just think it'd be a trick thing to do. Anybody shed some light for me?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
