Wiring harness for oil pressure and level
jkholder09
Jan 8, 2012
1,188
Maryland
There is a smaller harness that connects to a 6 way connector up top, and goes down by the power steering pump to a ground ring, then the oil pressure sensor and then the oil level switch.
I know you make harnesses for the hot rodders.
Do you have any of these used you could sell or any you could make up I could buy from you?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
They use Sumitomo connectors which are hard to source...probably easier/cheaper to just get one from the junk yard etc.
jkholder09
Jan 8, 2012
1,188
Maryland
Thank you for the reply. I did price out some pigtails for the 2 sensors but the 6 way connector is not available. I may end up splicing it all together.
meeksn01
75
3 prong instead of 6
My trucks an 01 and has a 3 prong connector instead of a 6 prong connector on the block wiring harness right above the oil pressure connection does anyone know where it plugs in at?
