Thank you for your help I think I am gonna try that. Question do you need to put anything on the bolts going through the tubes so they won't leak air??
No Prob, :hug:
I wouldnt go through any tubes with bolts and what not. Not only is an air leak possible but the risk of somthing coming loose and getting into the turbo would be catastrophic! Thats why i recomend using a t-bolt clamp (like a stock duramax boost clamp) and put one around your AFE pipe by the turbo. Once you tighten the clamp around the pipe, you'll have threads of the T-bolt clamp left over that you can use to put a boost tie-bar on OR weld a tab on that T-bolt clamp if you can? That way you can hook a tie-bar from the clamp to a bolt on or near the turbo to keep the AFE secure
I included a pic of a T-bolt clamp with a tab on it to show you
You could do a tab in what ever way suits you the best. If you like that one, its from Dynatech, jegs.com carries them, in the exhaust section, just need to find the right size for your AFE pipe!
One other thing, if you havent, might give the intake manufacture a call, could be somthing they'll help with?
And maybe to save you some hassle, a fresh silicone coupler and 2 t-bolt clamps might keep it from falling off? Just an idea to maybe save you some effort
Glad to help!
