Thought a 1058 would be enough like I was told![]()
you put your trust in the wrong people
I wonder what results you would see with just switching back to a set of pyo's and some cheater slicks or even just A good tire.
These are exactly what I suggested as well. His truck needs caltrac setup work, better tires, and more fuel and I would bet she RIPS! his converter seems to be the hold back for 5500ft elevation as the logs show he was only 2200rpm as he tried to spool and just couldn't get on top of the charger without really long stage times no matter how we adjusted tuning even though that helped.
At 1600uS, he's got a lot left with dual pumps lol
Brian you have big fuel down low and plenty of it to light that charger, it's not that.
Just did 2 back to back runs on my test road, and spool time from idle to 15psi was 7 seconds. MUCH better down here. I also think my lack of big fuel down low may be hurting it, but we will see in October after the track opens back up again.
Im going to keep the current housing on the turbo, see where it's at and go from there. I don't plan on racing at 5500' tracks anymore :rofl:
Needs cal tracs
That turbo can be tuned to spool rockets fast tliq and timing. but still want a better converter
Dual stock ppumps he can easy go another thousand us but I bet a 2400 would get his 10.99
James big fuel doesn't light turbos. Heat does
Your gonna end up frying that converter so just semd it to suncoast and gwt thwm to re-stall it
Been waiting to hear from Mike on how his new Goerend converter is doing in Anthony's LMM. May give that a shit.
He's got cal trans but they need time on them to get adjusted correctly. I wasn't allowed to touch them up there lol. Thing squats REALLY hard on the rear, Almost like a 2wd setup.
Yup, we were throwing lots of timing at that thing compared to where he started at and we cut spool up almost in half compared to before. That's why I was sayin he has plenty of fuel down low. Problem was is he didn't have any sort of timing calc on the computer so I was throwing timing at it blindly and I didn't want to go too far so we played it conservatively. Still waitin on him to send me that tune to see where we were.
X2
7 sec is terrible! Aim for 3 sec
Guess I need to call suncoast and see how much a restall would be for when I need to pull it back out.
