What kind of Gauges are you running?LB7
Taylor-34
Jan 13, 2014
443
Cali..
Old truck came with in installed glow shifts installed em and finally hooked em up the week before I sold my lly they sucked lol, looked good lights weren't too bright but the needles were inconsistent ordered auto meters for my new truck we will see.. Was told to make sure and have em hooked up to a dimmer otherwise they're bright as hell so hopefully that works.. They were free so if I don't like em ill chick em out and go with isspro
2003Duramaxlb7
May 4, 2014
99
Pensacola,FL
Ya My buddy had autometers on his old LBZ, he said he liked them.. I've been looking for a set, just not sure what I want.. Plus dont want to spend the money and get some that are going to crap out after alittle bit of use..
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
After messing with pillar gauges I said screw it and went to the insight CTS. So glad I did its way better then a row of ugly visible gauges.
07metallicgreen
Nov 24, 2011
207
Smicksburg, PA
I have pro parts spek gauges and love them. They have peak recall and warnings built in. You can also dim them and pick the color. Little pricey but worth it.
Posted via Mobile Device
AKlowriderZ71
May 14, 2012
719
Wyoming
Stock cluster with an Edge CTS. Makes it possible to see more than just 3 aux gauges, any PCM parameter, and I also added a backup camera. Makes backing up & coupling trailers a breeze.
Combine Pilot
They Call Me Mike
Feb 7, 2010
647
Saskatchewan
Isspro EV2's
jacobdewey
This won't last long...
Jan 14, 2011
972
Peak boost is 24 psi off your map sensor using the edge insight. I use the cs in my overhead console so it's hidden from people's veiw.
If you buy a pressure sending unit, you can set it up to read off your edge with the universal input and eas expandable cords.
bevi
Jan 17, 2010
709
Nh
Iss pro v2 and a insight
2003Duramaxlb7
May 4, 2014
99
Pensacola,FL
Very Nice, Whats the Stock Numbers an lb7 should push out for Boost... Kinda Leaning on getting the CTS now, But then dont want to have to fork out the other cash for the probes and such.
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
23 is as high as the CTS will read without the added pressure sensor for it. You still have to buy a probe for an egt gauge regardless if its the CTS or a single gauge
