Dad and I succesfully completed the water pump and housing replacement in 6 hours including lunch.
The metal tube going from the upward face of the housing to the thermostat housing (correct?) sure made it a royal B to get the assembly in and out. However, it was also very wobbly loose in that housing... Should we have removed it and changed the O-ring? We couldn't figure out how it comes apart.
Also, do these trucks normally take for-freaking-ever for the thermostat to pop? It took ever bit of 30 minutes at idle before the stat opened and it gulped down the new coolant. It took 1.5 gallons with the stat closed, stabilized, then took 3.5 more gallons.
