Van thermostat housing on LBZ
moparkxracer
2,309
33
Out and about
I have an LMM, not sure how much difference there is on them. But I had issues with the hose running on fan shroud and dual cp3 pully. I trimmed the shroud when the hose ran. I also cut some off the hose so it would pull away from the cp3.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Bumping this up. What is the short aluminum oil fill tube from and anyone have a part number for it? Or where to get something similar?
You can use an lb7/ lly oil fill of you can find one. That's how mine is.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Ya the motor is an lly but i am making myself a new thermostat housing and need the short fill tube in order to gain clearance to make it how i want.
If your making a housing go ahead and cut the tube down and weld it back together.. It's free
kivetts04dmax
May 20, 2010
742
Boonville, MO/Pendleton, CA
anyone running this setup with flex-a-lite fans? I think I may have burnt up the DS fan motor yesterday. It was idling while I was talking to someone and I could smell an electrical fire, lifted hood and fan was smoking so I disconnected them, turns out my rad hose was tight against the fan so it wouldn't spin..anyone know what else I could do other than zip tie it to the radiator? I have 1/16" between the compressor and hose now as it sat on the fan..
S Phinney
4,008
Quncy, Fl
Mines on a lb7 but what I do is place it on the housing with it rotated up tighten it and then pull it down to my radiator. Tension keeps it from putting pressure on my fan assembly.
PACougar
2,105
El Dorado Hills, Ca
I did the same thing, but I also added a zip tie through the metal top plate to ensure it can't ever make contact. In case anyone uses zip ties in the engine compartment, make sure they're nylon.
kivetts04dmax
May 20, 2010
742
I don't think the clamp loosened, I think the heavy duty zip tie I had on there just got soft when hose heated up and sagged, I wish there was a way I could do a stainless braided hose or something that had a better fit..
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,538
35
Lexington, Ky
I did the same thing on a set I installed last weekend. Zip tied it too
