Upgrading the LML Camaro
Jakezed22
158
53
Starting to plan out some fuel/air upgrades to the LML in my 2014 camaro.
*Do not want to do compounds* *Have FASS 120 GPH lift pump and stock LBZ cp3*
Engine is rebuilt stock with ARP studs. I feel like my goal is 700hp but i am limited by the 6l90e. So basically looking for recomendations on how you would move foward with injectors, cp3, and turbo. Looks like the limits of the stock components are in the 600's
This is what iv come up with so far: 30 or 45 overs, Stock cp3 or adding second stock cp3, Drop in danville turbo or something similar.
Whatcha think? Am i on the right track? Maybe some isnt needed?
Also looking for someone to do tuning, my choice so far would be motor ops. If someone else is interested shoot me a pm lets see what we can do. I found a guy not to far from me that has a dyno.
Reactions: KRODMAX/KS
812
I don't know if you have A CP3 kit already installed on your LML or if you need a full kit.
I would get a Fleece Performance PowerFlo 750 CP3 and Dynomite Diesel 30 percent.
The Pump is rated to 750 HP and the DD 30 percent injectors are rated to 725 HP
I think Dynomite Diesel is having a sale currently. Check with @Bdsankey He is a dealer for both suppliers and he may have other fueling options for you as well.
Bdsankey
3,906
1,074
Neenah, Wisconsin
Personally I would go 10mm pump in your brand of choice (I tend to stick to Exergy, S&S, and Fleece mainly) as well as a 45-60% injector in your choice of flavor (I tend to stock to Dynomite Diesel, Exergy, and S&S). Dynomite Diesel is having a 5% off MAP (roughly 10% off retail) sale until 3/15.
As for a turbocharger, we use and sell quite a few of the JZ Mfg units. He used to machine them for Danville and has helped a ton in the R&D side so he is no newcomer. A 63.5/66 would get you close (625-650whp conservatively) and a 65/66 would definitely get you there (700-750whp conservatively).
Reactions: Jakezed22
Jakezed22
158
53
Bdsankey, Would you be able to send me some pricing on a cp3 injectors and 65/66 turbo please.
