How many guys are running twins on a stock motor? I really want to twin my 4088 but not sure how long the motor would last even with conservative tuning. What all would have to be done besides the bigger charger and tubing?
i'm running twins on a stock motor and trans
I put over 80k with twins on a stock motor with a single cp3......Its the fuel that makes boost, so you could put a big set of twins on a stock motor, and after you get the motor built add another CP3
I was thinking about getting a s480 as a big charger?
while i agree with your statement i never thought so little fuel would make so much boost , its not a bad thing :driving: i just never thought it would do it , 2800 usec 50-60 psi dep on gate setting , 2600 usec 48-55 psi dep on gate setting . stock injectors 24200 psi cammanded . have not tried anything smaller yet .
You are right Trent, but you are running a big set of twins, the original ones for the lb7, lly and lbz won't have that much boost unless you really fuel them, (been there done that on my 02, 8 bent rods to show for it). I running what Nathan calls his small set on my 07 classic, I hold the boost to 43 lbs on my stock motor and have zero problems. I don't run an all out race tune in it, just one Rob calls a hot street tune. Runs great, good egts, great mpg if you don't hot rod it too much and does very respectable at the track.
Well the majority of that makes sense except the tunes. I am running a good hot tune with my 4088 right now. If I were to go with twins, obviously I would have to run a lot more mild tune but would the performance still be there? What I guess I am trying to say is I push around 40 lbs of boost with that 4088 and if I went with twins and pushed roughly the same, would my truck still be as fast?
I went .4-.5 sec quicker and gained 5mph on a tune with 450 usec less then my old race tune .
What was the difference in boost? Would from a roll and streetability still be about the same?
