Hi all, my LMM in Nissan Patrol has been running real good with Garrett 4094 Turbo, just recently I am seeing the turbo vane positions stick at 100% on hwy cruise and 0% when at idle, this is only after hard accelerate on any tune (dsp5 set up). If I drive it easy on any tune it does not happen at all, until I hard accelerate, it willthen set at 100% when running along and only drop to about 94% when backing off, then will drop straight to 0% at idle and as I accelerate it runs straight back to 100% and stays there.. A bit odd! If I turn it off, everything will be fine (vane % moves around) unless I hard accelerate again..
Normal operating it sits about 84% on cruise and moves all over the place when on and off the throttle, as it always used to but not now...
No codes ..
any ideas ? thanks
No codes ..
any ideas ? thanks
