LB7: Turbo surge?
dirtydmax
<---up shit creek
Sep 1, 2013
1,107
9
47
muskoka,Ont Canada
I have been fighting this intermittent violant shake of some sorts and really don't know what the issue is.have changed all 3 cp3's,flashed back to stock but have yet to catch it in a log.Its always under high boost 45-70 psi and gauges dont flutter being electric so it's hard to tell if it's fuel or air related. This new one for me.Thanks in advance.https://youtu.be/nuJ71SJHjew
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
What rpm is it happening at? If the converter is unlocked and you're making 70 psi boost, you're likely blowing through it. Does it do it in lockup also?
MarkBroviak
DMax Junkie
2,231
740
Danville Indiana
No problem, you will want all the normal important pids like rail pressure desired and actual, rpm, tps, vss, MM3, Main us, Ign Timing main ect. As violent as that looks I would say it is either Torque convertor signal dropping or crank signal dropping out or one hell of a rail pressure bounce to be that violent.
dirtydmax
<---up shit creek
Sep 1, 2013
1,107
9
47
muskoka,Ont Canada
My rail does bounce but not sure an that moment,There is definitely a pucker factor.
