Truck stuck in limp mode
GSXRTURBO1
Feb 10, 2015
139
Detroit MI
Not trying to answer for Mike L, but I'd check the connector to see if the pin for 71 has backed out based on what Mike L has posted.
cat_dr.
257
Jackson,Al
Thanks. Open to any suggestions. Mainly what I was asking was if pin 71 was input/output or what. Whether voltage should be coming from tcm side or harness side
cat_dr.
257
Jackson,Al
Tcm pins look good. Clear code and have these 3 that keep coming back
15,686
Does wire 71 have 12V or better? Looking at the pins tells you nothing unless it's damaged. Voltage will be coming from the battery. You need a wiring diagram and a DVOM. The diagram will tell you where 71 goes. Check voltage at the source then follow the wire down to the TCM and see if there a break or rub through. Check all fuses.
Check voltage to the trans with a professional scanner.
Once you fix P2670, the others might go away as well.
cat_dr.
257
Jackson,Al
The way it limped makes me think I have something sticking it the valve body. I'm no transmission expert. But I contacted the builder and that's what they are sending so hopefully it will
