I broke the crank in my LBZ, I picked up a complete LLY engine to use in the truck. I Pretty much only used the short block from the LLY, I swapped over the entire top end from my LBZ heads, intake, CP3, injectors, fuel rails etc. I also changed out the reluctor wheel and timing cover from the LBZ over to the LLY.
I have it back together and in the truck it cranks but will not fire, I logged fuel pressure while cranking it builds over 6500psi.
Thanks
Thanks
