Well went to the track Friday night and I finally broke into the 7s. My time was 7.94 and a 1.4 60'. Not sure how accurate this slip is or if the solar system aligned just right because I'm usually around low 8s but it's hard to find that consistent launch...
Here's the kicker that was on 305/45/22s and to top it off my rear shocks are bottomed out because they were the same ones I used with my 6" pro comp lift :roflmao:
Next time I hit the track I should have some qa1s in the rear and a new steering stabilizer. Keep in mind I have the basics covered to keep my front tires pointing straight but I'm having the toughest time from keeping my rears from spinning even in 4wd. My rear barely squats at all during my launch. It's hard to say what's causing my rear wheels to spin but I'm just not sure what I need, it got worse after I rotated my tires too. There's a lot more to it but I'm not trying to write a Novel here. Any tips would be appreciated..
