F0301 enter the maximum capacity of the tank. F0302 enter something a couple of gallons less. (Not sure why this is just how the factory did it)
F0303 enter the same amount there as in F0301.
F0101 enter the maximum capacity of tank in gallons starting at 0.00 volts all the way through 0.76 volts.
Then I left everything over 2.46 volts stock. And filled in everything in between 0.76 volts to 2.46 volts trying to mimic the shape of the factory curve as much as possible.
It's not perfect but it works pretty well. And I've ran it until the light comes on and been okay.
But I can also tell you that when I first installed my Titan tank I put 5 gallons in it, bled the system, and drove to town to fill it. And on the way going up hills I could feel it cutting out like it was running out of fuel. So I would be leary about running a big tank to low.
