Transfer case issue
Lance LB7
Nov 5, 2013
Kentucky
Any guesses on what's going on in my transfer case? A few months ago it started rattling and making a vibration around 70mph. Now it does it from 55 up. I can hold the tcase shifter forward toward the neutral position and it quits making the noise. When I changed the oil in it, I pulled a quarter size glob of metallic stuff out of the drain plug. Also, you can take the driveshaft and move the tail shaft maybe 1/8 of an inch up and down. It also looks like the tail shaft has slid out about 1/2 inch. It was rebuilt with the pump rub kit 70k miles ago.
chrisuns
283
San Antonio, TX
My guess would be the output shaft bearing machined surface and the bushing is wore. I'd check the driveshaft balance too, once I figured out what's wrong with the case internally.
Lance LB7
Nov 5, 2013
Kentucky
Is that bearing something that can be replaced easily? Or has it screwed up the housing?
chrisuns
283
San Antonio, TX
Well, if it's the bearing; it won't be a bad job, 2hrs or so. However, if the machined surface of the case half is damaged, you'll need a new case half.
At this point, I'm pretty much guessing as to what it could be from my experience - hard to say 100% without taking the case apart and taking a gander.
But the bearing, machined surface and bushing would be my suspects.
chrisuns
283
San Antonio, TX
Meh, besides he puts some fancy paint on them and uses factory parts and a pump rub kit claims they're "built". I wouldn't mess with him.
Lance LB7
Nov 5, 2013
Kentucky
You need to fix it quick before it wipes out your whole case. I had the same issues and 2 months after making a thread about it my transfer case imploded.
http://www.duramaxdiesels.com/forum/showthread.php?t=52062
http://www.duramaxdiesels.com/forum/showthread.php?t=55248
Did you end up rebuilding it? Or just getting a reman one? I work like 70 hours a week and this is my only vehicle so that's the biggest obstacle in my way right now. I was only gonna use Nate because he quoted me $600 and said he could rebuild it in 45 minutes while I was there...? Idk. Never been inside one don't know how complicated they get
CarolinaHD
969
NC
I had the dealership install a reman. They had the cheapest price(not including labor) and the best warranty and thats what other members recommended. If you're mechanically inclined and never done it before you could swap transfer cases in about 2 hours.
3 years later and my output shaft has slop and the seal is leaking... Just ordered my parts from Merchant and gonna do it myself this time.
Lance LB7
Nov 5, 2013
Kentucky
Taking the case out is no problem... I've had the clutch out of it 3 times lol. So your dealership reman only lasted you 3 years? How high do they run?
Lance LB7
Nov 5, 2013
Kentucky
Thrust plate in the planetary, tailshaft bushing, range fork and new tail casing is what it took to fix it. All good again
