I would like to dyno the truck before I twin it. What do I need to change in the trans tune to hold it in 3rd gear?
i never had much issue with the DVT but we would turn the function on, click "4th gear" while it was rolling along in 5th, wait for the down shift and converter lock, then 3rd gear to see if it would down shift to 3rd as it should, then click back to 4th gear, then do the dyno pull and do this over again on the next run. sounds like alot but its simple once you do it a time or two. it will hold the gear every time then. only time ive had it not work is back to back runs and not following my little system. i think completely letting off the throttle kills the DVT from working but who knows...
