LBZ: Trans go Jr install help
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
59
belvidere,ill
Installed a trans go Jr in an 06 lbz and it had foraward gears to pull ahead in the shop after install and we went to back out of the shop,it has reverse but no forward gears and says shift range inhibited.Took the valve body back down and went over everthing check the trans plug and all seams as it should.Any ideas?
dordtrecht5
Regular Cabs Rock
Jul 21, 2009
900
Wherever I am working
I had that happen to me once before and it was a solenoid that wasn't plugged in at the valve body. But, since you had the valve body back out I don't know what it could be.
Mike L.
15,681
236
Fullerton CA
Checked with v2 no codes at all
V2 may nut cut it for hidden codes. You will need to moniter the data stream and look at all the solenoid parameters, speed sensors and such to see what is not working. It's there; you just need to find it.
