Can somebody tell me the torque spec for ARP studs?
Vrabel TOYAHOLIC May 22, 2008 3,434 0 0 56 Hewitt, NJ Jun 6, 2011 #1 Can somebody tell me the torque spec for ARP studs?
KEVINL Well-known member Jul 4, 2008 1,431 43 48 41 Phoenix, AZ Jun 6, 2011 #2 Head studs? 125lb ft If they are new they have to be torqued and loosened three times to get proper strech
Vrabel TOYAHOLIC May 22, 2008 3,434 0 0 56 Hewitt, NJ Jun 6, 2011 #3 not new. thanks. I had to remove drivers head to inspect something. Do they get re-tightened once for gasket setting still? (Yes, it is a new gasket.)
KEVINL Well-known member Jul 4, 2008 1,431 43 48 41 Phoenix, AZ Jun 6, 2011 #4 Yeah once is fine for used studs i usually go in steps 60, 90, 125 lb ft
slipclutchms Member May 24, 2010 427 0 16 Jun 10, 2011 #5 The new instructions provided with the studs from ARP state that you tighten them only once
ripmf666 Active member Sep 20, 2006 15,123 14 38 47 Wentzville Mo Jun 10, 2011 #6 slipclutchms said: The new instructions provided with the studs from ARP state that you tighten them only once Click to expand... You do the once I will stick with the old way that works never failed us :hug::spit:
