Top 53 RWYB Street Legal List
DetailsUnlimited
1,264
Benton, Ar
12.02 @ 112.56 driven 12 hrs to world finals and then back home. Has had a trailer attached to it 99% of its life. Stock motor, turbo and injectors.
3,796
423
Well congratulations to the first 21 on the list :woott:
Now if I can just figure out how to make it display correctly we will be ok. If anyone knows an easier way to post a table on here let me know please
You can put it in CODE tags so the spaces stay lined up:
Code:
[U][B] #  Screen Name         Time    MPH     Body    Year Engine[/B][/U]
 1. cafryer             10.5    132     RC/LB   2001 LB7
 2. bigbird             10.76   127     CC/SB   2002 LB7
 3. Dan@PPE             11.17   126     CC/SB   2002 LB7
 4. Harbin_22           11.60   119     CC/SB   2010 LMM
 5. ctrump90            11.601  113.05  EC/SB   2003 LB7
 6. Vsouth              11.72   118     CC/SB   2006 LBZ
 7. 05Chevy             11.78   114     CC/SB   2005 LLY
 8. paint94979          11.84   115             2005 LLY
 9. DetailsUnlimited    12.02   112.56  CC/SB   2006 LBZ
10. DIESELMAFIAPER.LB7  12.17   111     CC/SB   2003 LB7
11. Slammmed 2007LBZ    12.23   109     CC/SB   2007 LBZ
12. Noreaster           12.26   109.02  RC/LB   2002 LB7
13. S phinney           12.27   113     CC/SB   2003 LB7
14. BUST'EM 504         12.32           CC/SB   2006 LBZ
15. Chevy1925           12.39   113     CC/LB   2002 LB7
16. 03_DMAX             12.42   111     CC/SB   2003 LB7
17. SSchmi5519          12.564  107.99  CC/SB   2005 LLY
18. jacobdewey          12.6    106.86  CC/SB        LB7
19. 1slomax             12.63   106     CC/SB   2005 LLY
20. Devon               12.95   104     CC/SB   2004 LLY
21. dmtcm               12.99   103     CC/LB   2007 LBZ
22. DAVe3283            13.172  104.83  CC/SB   2003 LB7
23. whitetrash21        13.3    108     CC/SB   2005 LLY
24. rickettzusaf        13.56   100.008 CC/SB   2007 LBZ
25. jnieberlein         13.852   91.32  RC/LB   2006 LBZ
[B]Gone :([/B]
[COLOR=Red]26. Lotsofmiles         14.7    100.05  Van!    2006 LLY[/COLOR]
Might be easiest to edit it in Notepad, then copy it back into the CODE block.
Sadly, lotsofmiles got bumped. And I made it in before the rest of the fast people notice this thread!
3,796
423
We are missing some data:
  • paint: what body style is your truck? I should probably know, but I do not...
  • BUST'EM 504: what was your MPH?
  • jacobdewey: What year is your truck? Also, do you have tenths and hundredths on your 12.6xx run? It might be the difference between 18th and 19th.
  • Harbbin_22: Do you have the hundredths from your 11.60x run? It might be the difference between 4th and 5th.
If you post up, I will update the list, or someone else can feel free :thumb:
3,796
423
Top 25 RWYB Street Legal List
Code:
[FONT=Courier New][U][B]##  Screen Name         Time    MPH     Body    Year Engine[/B][/U]
 8. paint94979          11.84   115     CC/SB   2005 LLY
10. DIESELMAFIAPER.LB7  12.175  111.84  CC/SB   2003 LB7
18. jacobdewey          12.605  106.86  CC/SB   2003 LB7
23. whitetrash21        13.301  108     CC/SB   2005 LLY
[B]Gone :([/B]
[COLOR=Red]26. Lotsofmiles         14.7    100.05  Van!    2006 LLY[/COLOR][/FONT]
Still missing:
RPM Motorsports
smokinum
May 13, 2008
3,271
10
Central Valley Ca.
D-max powered or Factory equipment only??
10.702 @ 129.7 For the Chevelle. Hand calculated 31cty/35hwy, and daily driven so much that Ricks D-max truck stays in the driveway because of the Chevelle's fuel economy.
maxpower91
May 29, 2010
49
10.937 at 127.16 Drove it 300 miles to byron il dragway and 300 home on nitto 420s's.. drive the truck regulary.. it is a 2002 gmc ec/sb lb7
juddski88
Freedom Diesel
Jul 1, 2008
4,659
130
Chesterfield, Mass.
I had a best of 11.12 @ 123.9 mph in its current street trim 10/5/12 at NED in NH. Truck weighed 6000 lbs, fuel only, toyo proxes on h2 rims, no cryo2, 27deg timing and 2400 ms pulsewidth, 50psi, 1700 deg egt. Tuned by Slipclutch Motorsports.
3,796
423
Code:
 3. maxpower91          10.937  127.16  EC/SB   2002 LB7
 4. juddski88           11.12   123.9   EC/SB   2001 LB7
 5. Dan@PPE             11.17   126     CC/SB   2002 LB7
 6. Harbin_22           11.60   119     CC/SB   2010 LMM
 7. ctrump90            11.601  113.05  EC/SB   2003 LB7
 8. Vsouth              11.72   118     CC/SB   2006 LBZ
 9. 05Chevy             11.78   114     CC/SB   2005 LLY
10. paint94979          11.84   115     CC/SB   2005 LLY
11. DetailsUnlimited    12.02   112.56  CC/SB   2006 LBZ
12. DIESELMAFIAPER.LB7  12.175  111.84  CC/SB   2003 LB7
13. Noreaster           12.26   109.02  RC/LB   2002 LB7
14. S phinney           12.27   113     CC/SB   2003 LB7
15. BUST'EM 504         12.32           CC/SB   2006 LBZ
16. Slammmed2007LBZ     12.33   109     CC/SB   2007 LBZ
17. Chevy1925           12.39   113     CC/LB   2002 LB7
18. 03_DMAX             12.42   111     CC/SB   2003 LB7
19. SSchmi5519          12.564  107.99  CC/SB   2005 LLY
20. jacobdewey          12.605  106.86  CC/SB   2003 LB7
21. 1slomax             12.63   106     CC/SB   2005 LLY
22. Devon               12.95   104     CC/SB   2004 LLY
23. dmtcm               12.99   103     CC/LB   2007 LBZ
24. DAVe3283            13.172  104.83  CC/SB   2003 LB7
25. whitetrash21        13.301  108     CC/SB   2005 LLY
[B]Gone :([/B]
[COLOR=Red]26. rickettzusaf        13.56   100.008 CC/SB   2007 LBZ
27. [/COLOR][/FONT][FONT=Courier New][COLOR=Red]jnieberlein         13.852   91.32  RC/LB   2006 LBZ[/COLOR][/FONT]
Still missing:
  • Harbbin_22: Do you have the hundredths from your 11.60x run? It might be the difference between 5th and 6th.
