Today I went and tried to swap out the factory keys for a set of green keys. I was able to get 1 side done no prob but the passenger side key is stuck on the Tbar itself. I tried with an air hammer but it's stuck pretty tight I guess. Question is where should I heat it at? I assume start and heat all visible areas of the key correct? Could I try hitting the key with the air hammer and see if that knocks it loose? I don't have a torch so I'd like to be able to try things in the garage first before having to go find a friend and use his.It's sitting pretty level side to side right now but I'd rather get both green keys in instead of having 1 stock and 1 after market key in.
