Stupid Question
Krazykid
<-Daily Thought Process
Nov 22, 2008
247
Upstate, SC
Im currently trying to get to the heads of my LLY to replace the gaskets. My stupid question is this. After unbolting the intake bridge is it possible to unbolt the rocker arm assembly fully assemble to get to the heads? Sorry if this is not an accurate description, this my first major overhaul of a motor. I believe the assembly has like 12-20 5mm allen head screws?
ripmf666
15,123
14
49
Wentzville Mo
Also Shawn sorry I did not get back with you Fri night after your pm. I was stuck on the phone dealing with Gm going back to work and they screwed my checks up. Did you get all your parts you needed. Good luck just take your time. All info that you need to do this is listed in the Gm spec area tells the step by step on taking off and reinstall.
