My #7 had EFI dsp5 by EPR a fass 150, mbrp 4" Exhaust, PPE Valve, and stock intake and made 548hp on Industrials Dyno and 549hp on Hallers Dyno, 547 on Custom Auto's Dyno. Since then I have added ported turbo inlet pipe, Diamond Eye Down Pipe and AFE Stage ll intake. I am curious to see if I gained anything. I know my tune #2 made 542hp and held rail. My big tune drained the rail down to 18k but still put good #'s down. A set of twins and a dual C would sure help out!![]()
You prolly wont hit 550 on the stock IHI turbo unless you spray it. At even that I wouldn't do. You'll see 500-530 if your CP3 is healthy. But every dyno is different.You can be my stock turbo idol lol
Im hoping for around 550 but we will see. Ill post when I get the truck complete.
Seems like some people have laid down alot bigger numbers than I was expecting with stock pumps.
Whats the cheapest way to get a good dual fueler setup? minus the pump?
That would be the cheapest. Then buy a good used pump. Personally I would run what you got. Max effort tune and see where it takes you. Anything around 500hp is a blast to drive. Often wish I would have stayed at "stock" levels instead of twin-everything-money-pit haha.
I know the LLY is a bit different but I made 576 on fuel and 614 on spray with a stock LLY pump. My buddy James' LB7 made 540 on a stock IHI, cp3, and sticks.
Plenty of people are spraying nitrous. I happen to love it. My turbo.....not so much...When you guys say spray you mean nitrous or water/meth? If nitrous you are brave haha
Yep.... It will sound rough at idle.... The rail pressure will be quite high. But it will start and run
I have eent 685hp on stock cp3 40% overs and single s475. Converter wouldnt stay locked pass 3200rpm
