Spongey Clutch Pedal
Lance LB7
Nov 5, 2013
Kentucky
I bought my truck with 170k on it and at 174k I pulled out a luk single and solid flywheel and went with a ky clutch single. Ever since I can remember the clutch pedal has felt "spongey" at the top. On cold mornings or if the truck sits for a few days the pedal will sink about halfway down and ill have to pull it up with my toe. Even after a full day of driving I can always pull the pedal up with my toe about half an inch. On other ZF6's i've driven, the clutch pedals stay all the way up all the time? I've bled the master cylinder and even replaced it. any ideas?
Sud
May 15, 2012
56
Lawrenceburg, KY
mine doesn't seem to "sag" like that... i guess it's bled out as much as you can? (pumped the clutch pedal ~100 times. not really 100... but then again, it might take that much. Just pump and pump and pump.)
After pumping the pedal does it still sag, or come back up where it should be?
Lance LB7
Nov 5, 2013
Kentucky
Do you mean pumping it that many times when bleeding the master cylinder? if so then no. I usually only pump it 8-10 times until the pedal comes back up
