Slicks air pressure
jedenbeck
Aug 11, 2015
19
Just bought a set of 30x14 cheaters on 16x10s with tubes in them. What’s everyone running for air in them? I’ve never ran a slick so I’m starting with no knowledge of them pretty much.
Thanks
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,087
31
Mexico
I’ve always had great luck with these numbers.
For 6700-7k lbs 28F/22R for 6400-6700lbs 24F/18R. Will have to check/adjust after each pass.
jedenbeck
Aug 11, 2015
19
Thanks for the tips. I’ll check them after each pass. What’s the reasoning for that? They fluctuate a lot? Just curious
SickLL7Crenshaw
Billy The Kid
Mar 10, 2013
1,087
31
Mexico
Tire psi will rise after a pass due to heat, depending how long you wait until you’re next pass pressures can vary. I always check just because I’m OCD about little things like that. Direct sunlight hitting them will cause a psi jump as well.
Ne-max
I like turtles
Nov 15, 2011
3,361
62
Lincoln, Ne
A lot will depend on your race weight. I run mine at 22 in the front and 18 in the back. But I'm not running tubes. With them you can run a hair less then normal. Also power plays a huge roll. I would not run them as low if they are working the same with higher psi.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,558
167
P.N.W
Can't remember what i ran last year on the 30x14 M&H cheaters but I was a little under 6700lbs so I will try out the 24F/18R this year and go from there.
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
22-24 front and 18-20 rear have done well for me a 6400lbs.
Sent from my SM-G965U1 using Tapatalk
