SLC turbo talk
cdbright
JUST RENT IT
Dec 16, 2008
1,010
Salt Lake City, UT
i have moved back to SLC, UT and the turbo lag is obviously horrible, and with a stock trans still, is going to a Variable bigger stage one going to make it worse? i assume the best way around this is going with twins, which i want but my stock trans wont hold, i guess i should stop thinking anything boost wise before i do the trans right???
i prob just answered my own question:(:(:(
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
If your running a stock turbo and having lag problems, you either have sticking vanes, or a tuning problem.
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I ran twins for a couple years before I got a built trans... Not ideal but it was fine for me.
Your 6 speed will hold more power than my 5 speed will but as James and Iowa mentioned you shouldn't be having spool up issues with a stock turbo. Some of the most impressive trucks I have ever tuned are the LMM's with just minor bolt ons and stock trans.
cdbright
JUST RENT IT
Dec 16, 2008
1,010
Salt Lake City, UT
truck now has about 93K on it, not sure if first owner ever removed , it must have had a DPS switch in it at some time cause when i installed mine i found a pin left in the harness, was not fun to dig out
