Single turbo Diablo
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
55
Tampa, FloriDUH
thought you guys might like to see what i've been stuck working on for the past few months....:eek:
picture time...
the last one i personally had to put the "turbo" emblem on just for the pic...lol it's NOT a permanent thing...just for the picture.
3,681
236
Missed this until now. Looks sweet! Did you get to test drive it, or was it stuck to a dyno the whole time?
That much power has got to be a handful in a car that light. :eek: :D
Sent from my Galaxy Nexus using Tapatalk 2
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
55
Tampa, FloriDUH
dyno #'s where in "2wd" (front prop shaft out), then i put in the front shaft to make it drivable on the street, it is a blast, boost comes in low and quick, but honestly, the turbo exhaust wheel is way too small to run more boost as the drive pressure has to be nuts, since we ran the boost up to 15 psi and it only netted 20 more hp...a larger turbo is in the future current is a BW s400 s372(72mm)...we plan to switch up to a s400 s387(87mm) and shoot for 1100 rwhp with air/water coolers added in the mix, this was a very basic "kit" to see how things worked :thumb:
turbo-max
WaaaZaaaa
Aug 9, 2006
1,037
55
Tampa, FloriDUH
also i have been playing with a 2002 lexus is 300 with a v v t i supra engine/6 spd trans swap, it's only running 15 psi boost and around 400ish rwhp
