yea chris u could really benefit from dual fuelers
So twins are harder on stock bottom end? I thought it was the other way around due to boost? I'm just wondering because I'm in the same boat as Brandon, do 66/80 on stock bottom end (hate vvts) or another big single.
Only harder if you get greedy with a lot of fueling down low. Not an issue at all with a good tuner
I agreeI don't get why you guys like all that lag before it lights :hug:
I like the power to be smooth and come on sooner, makes for a much better DD/ much better towing ability. I don't think about keeping on top of the turbo towing, and drove it all winter in the snow and never got pissed at it.
I didn't know Scott was making triples, that's BA!! If I went with twins I'd wait till this new kit comes outif not I'd do a single billet 72 or 75, much easier to work on things if needed..
I prefer compounds.
Bottom end will be fine with twins you just need to make sure the person tuning your truck knows what he's doing. Keep the bottom end torque in check and all is good.but what about on a stock bottom end? If I buy a turbo(s) I won't use a vvt, never was crazy about them and would rather do away with..I've been searching for a twin setup that uses two fixed turbos but would still be nice for a stock bottom end with some fuel upgrades..
Also when people refer to the lag of a big single, It makes you think the truck is barely accelerating and just a sick slow lazy pig. In reality from a dead standstill if you just stab the throttle a truck with a big single takes off and accelerates pretty good. I pass cars at 55 mph and get around them with ease and the whole time I'm under the charger with very little boost. If I'm in a hurry to get around I bump it down to 4th and hope the tires dont break loose. I have a video on youtube that shows a 0-90 run I made looking at the tach and speedo. This run was from a stand still at idle, no brake boosting at all just stabbed the throttle. Keyword "LWATSON Duramax Billet S475".
Ive done a few 66/80 kits on lbz and they can be tuned to 650 hp pretty easy and live.but what about on a stock bottom end? If I buy a turbo(s) I won't use a vvt, never was crazy about them and would rather do away with..I've been searching for a twin setup that uses two fixed turbos but would still be nice for a stock bottom end with some fuel upgrades..
