Remote start
Troysalm71
286
Bemidji, MN
Was just curious if anyone has came across their remote start not working on a 2011 lml. I really wanna say it happened after the tuning. My remote an my back up Akers both don't want to work. Constantly says park assist blocked. My first tune was an h&s which has been off the truck awhile. I'm not sure that helps much as I've seen it screwed up these things on lml with h&s. It now has efi from kory.
kiwilml
454
Well mine has always worked, unless check engine light is on or hood isnt shut all the way..
And did you mean back up camera isn't working or sensors?
drperry
Jan 4, 2015
21
If you clear any codes, it should start for a second or so, and shut down, for a glow plug.
If it doesn't even fire, it's possibly something else...
Troysalm71
286
Bemidji, MN
I knew about check engine light. Ring on I've had that happen several times. Yes back up camera is not working I haven't taken any time to really look into it. Just figured I'd ask suggestions.
drperry
Jan 4, 2015
21
If your fuses are good, then mayhap something got turned off in the tuning... I'll browse the LML base file and get back to you, if it has something in it for those.
