rear suspension blocks?
616samuel
Apr 26, 2011
178
Rockford, Michigan
New to this site so sorry if it's been asked already, i did a little searching with no luck.
I pull in the "Stock class" with duramaxtuner.com's tunes, i have traction bars and bumpstops.
I was wondering if adding 1.5" to 2" blocks in the back would help at all with the added forward angle on it?
here's some links of last years pulls when i was running the ATS E-Power tuner on 315hp setting. it ran pretty good but i'm expecting alot better results this year with duramaxtuners tunes with a lift pump and MA built tranny and maybe bigger injectors.
This is my wife driving and ended up in 4th place after a pulloff for 3rd.
[YOUTUBE]kYer92wcJXg[/YOUTUBE]
This is me at Hart
[YOUTUBE]Pqw2wfeiT4E[/YOUTUBE]
all year my ground speed was around 22 -24 mph.
thanks in advance
dirttymaxx
Nov 15, 2010
334
sharpsburg,ky
do you take yout t bolts out? that will help with the rake of the truck but
from the video looks like the truck plans out nice. i coudlnt tell much from the 2nd video.
bubba2400
Jul 19, 2009
199
Union Grove, WI
I would not put the blocks in the back. The extra rake on the truck will not help enough when pulling off of a receiver hitch and can make it hard on the front end. JMO Should run good with the new tuning. Good luck.:thumb:
616samuel
Apr 26, 2011
178
Rockford, Michigan
yea, t bolts let all the way out, Might be the weight brackets on the hot diesel class making the other GM's back ends look way higher than mine... i was just curious Thanks!
maxpower91
May 29, 2010
49
I just installed the four inch turf country on my truck.. and running one inch blocks at the moment with caltracs that have a lot of preload.. should I do 2 or 3 or what?
bubba2400
Jul 19, 2009
199
Union Grove, WI
Stick with the one inch blocks in the back. Try to get the chassis so that it sits level when the bars are down. Unless it looks really bad when you have the torsion bars turned up anyways. Good luck with it.:thumb:
maxpower91
May 29, 2010
49
Alright. Sounds good! Just wondered cause I'm pretty sure Tony b runs like 3 or 4 inchers...
