Rear End recommendation ~ Towing 37' Toyhauler on 35" Tires
unmtv8d
Oct 17, 2011
Phoenix, AZ
I currently have a 2006 with the LBZ motor lifted on 35"s... I tow a 37' Fifth Wheel Toy Hauler and was thinking about re-gearing my truck which currently has the 3.73. Some are saying just put a 4.10 and others are suggesting up to a 4.56... Has anybody had or know similar situations and what may work best? Upsides and downsides?
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
Houston, TX
Calculate it out. You can figure up what your rpm will be at cruising 70. I'm betting 4.56 but math will show you where you need to be
Sent from my ADR6400L using Tapatalk
coker6303
Aug 6, 2009
2,484
Houston, TX
with 37's, this chart is comparing your 3.73 to 4.56 gears (looks to me like 4.56 is going to be perfect!). 4.56 gears and 37 in tires put you very close (within 50rpms) to the same cruising rpm at 70 as stock tires and 3.73.
you can find the calculator on grimmjeeper.com
coker6303
Aug 6, 2009
2,484
Houston, TX
he's running 35's...pulling a 37' trailer
oops, i'm moving slow! it's monday.
35's and 4:10's are within 40rpm's of stock at 70 mph.
You would be hitting 1900 rpms cruising with 35's and 4:56 gears in 6th at 70. if you're not worried about mileage, this will definitely be stout!!
D-MAX Mafia
Hood down, smoke up!
Nov 4, 2009
1,109
Phoenix
I run 4.56's, makes for a good street setup with the heavier wheels/tires. I have towed a few trailers 10-15k lbs and the lower gears make running hills pretty easy at high speed.
On the DroidX
jlawles2
1,044
33
Danbury, TX
I used 30.47" (245 75 R16)for tire diameter and had 2160 rpm @ 70 mph.
Circumference of Stock tire is calc'd at 95.72" while the 35's have a circumference of 109.97"
radvans
242
SoCal
I type a 40' w/4.10 and its perfect. No problem with power and didn't change mileage. Had like this for over 100,000.
crazycrew
Let's Start A Riot
Oct 3, 2009
1,230
42
S. Louisiana
My neighbor has 4.10 with his 35's and absolutely loves it. He said its exactly like when he drove home from the dealer
Sent from Mac Daddy Land
bartman432
Nov 4, 2011
242
I'm running a 4:10. This is what the gear intaller recommended with a 35" tall tire. I tow a 31' 5th wheel and it's perfect.
Colt
Jul 23, 2010
523
Are you changing the whole rear end? Dana 80 out of older Dodge ton up is priced real good with posi or what you want. That engine should run fine at 2K rpm don't you think?
