Rear Axle Crack
gmasko
73
Sacramento
So I definitely have a cracked axle housing. Since I bought the truck it had a moist spot where the helper spring support is welded on the axle. Really didn't show till the paint chipped off a bit. Now it's sweating oil through. Question is who's seen it before, and what's the input. I will weld it up but i want to fix the cause to not worry about it anymore. It's lifted about 6" with the bags on low pressure, so my guess is axle wrap but all I have is the edge attitude so is that enough power to cause a crack? Rule out off-road abuse, doesn't see much dirt. Or I've heard of improper welds making the metal more brittle? Thoughts on a permanent solution?
gmasko
73
Sacramento
Not what I expected to hear hahaha or wanted to hear anyways. OK so say I replace the axle with a similar setup and it happens again. That's what I'm getting at.
Oct 16, 2008
951
21
Idaho
Can't really see that much from the pics. Could just be a fatigue crack caused from years of taking a beating. This might ruffle a few feathers but if it was me, I'd drill the ends of the crack, bevel the crack and clean it real well, lay a good weld on it, then check it every time you think about it to make sure it doesn't either happen again or get out of hand.
Buying a new axle without knowing the root cause of the issue may land you in the very same spot.
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Not a bad idea Levi..
8,057
Do what Levi said, then grind the weld flush and plate over and around the tube/weld with some 3/16 plate. That will stop any more of this issue. I would do the other side as well
N2BRK
2,377
712
tubes are .5" IIRC. I'd do as suggested above and weld that bitch.
Dozerboy
5,088
683
TX of course
****k it run till she breaks. Had to of almost been a fluke. It takes a lot to crack one of these axles.
Awenta
4,090
Can you take a picture farther back? Maybe there's a stress point or I'm just missing something here. I agree with just welding it.
gmasko
73
Sacramento
Outstanding input guys, reminds me of why this is the only dmax forum I use. Wouldnt have thought to gouge the crack for a better weld bite. Hell I might even turn this into a small project and build some gussets for it. Ill post some better pics soon of the situation down there, might even have some fun with this.
gmasko
73
Sacramento
And .5" thick tubes definitely raises some questions in my mind. Reinforces my belief that this truck probably had the s**t beat out of it before i bought it with all the issues I inherited. (Of course im not perfect either)
Dallas S
496
Alberta
In my opinion I would replace that housing.
After all the time spent cleaning the housing, taking care not too put too much heat into the tube, bending the tube, taking weight off the tube... There is a pile of these diffs at ever wreaker. I think in the long run your better replacing.
N2BRK
2,377
712
I read 1/2" back when I had to weld tabs on mine. I welded three other Dmax axles since then. I set my 220v mig for 3/8" and welded some 1/4": thick tabs on there, spending more time on the tube, of course. No issues or blow through. So, I'm calling shennangans on 1/4", maybe on 3/8", but pretty certain that at least the NNBS's I've done are 1/2".
8,057
Yeah no one seems to have a straight answer. It's very hard to blow through a weld joint like that though so I wouldn't use that as your gauge. You have no edge to put a lot of heat into other than the tab so even continuous welding makes that hard to do on just 1/4 as that heat gets pulled through the whole tube and not really focused on an edge.
N2BRK
2,377
712
fair enough. But when I let my buddy run the squirt gun he eroded the shit out of the tube, lol. He must have gouged a 1/4", LOL.
I'd be curious to know the truth on this. It wouldn't surprise me to see 3/8" but no way on the 1/4".
gmasko
73
Sacramento
Gonna have to let my brother chime in on the weld lingo, he'll be the one putting the bead down. But on the topic of the welds, I've got a better pic. As stated that weld always had "wet" spot to it. As you can that's where the crack originated. Could it simply be a failed weld that finally showed it's true colors as the cause?
