LB7: Rattling black smoke and skipping
JustinD
Plow Truck
Nov 21, 2008
2,067
41
Tiverton Rhode Island
I was plowing snow last storm and my truck started to rattle and skip, sounds like a dead hole? EFI won't read the balance rates says all zero?? GM TECHII says all zero too? Took the glow plugs out one at a time and looked to see if one was soaked with fuel but they all look good? Any ideas? :confused:
Sledhead
Mountain Pass Machine
Nov 29, 2008
884
BC
Can you a get rail pressure reading? Other engine and fuel data to verify comm?
slipclutchms
427
someone one else was having problems reading balance rates and they were all 0. Try re-flashing to stock if you have not already.....then maybe go back to build 133 instead of 139?
Dylan
slipclutchms
427
also try re-validating the parameters......I have had that problem before. Try that first actually....
SHOTZY
<"Whats next??"
Aug 27, 2008
474
melbourne, fl
Is it throwing any codes? I'm guessing its an injector wire under the valve cover. My buddies lb7 did this. Balance rates all read 0 and sounded like a tractor lol. Good luck.
JustinD
Plow Truck
Nov 21, 2008
2,067
41
UPDATE:
I went to the shop on lunch break, EFI wouldn't let me turn injectors off one at a time??? So I grabbed the Tech 2 and fumbled my way through it and found the fuel menu I was able to turn each injector off when I got to #3 it smoothed right out, ordered an injector hopefully its the issue??
Back in the summer when I had fuel leak issues under the covers I read balance rates and 3 was off from the others, all the rest were .090 or .080, #3 was like 3.78?? So I'm hoping it just went bad over time?? I will post when it is done and running good hopefully!! I have more snow to plow!!! :rofl:
Bonestock
1,358
Worland Wy
Efi
I have seen this before and all I had to do was pull the shifter into neutral instead of park. Then the balance rates would display. Hope this helps for future.
