Good day guys!
Well I put my truck back together finally and well filled the coolant back up and next thing I know is that I have a constant stream of coolant flowing under the truck. I initially thought I hadn't screwed something back up right but I then noticed it was coming from the front and looking at the rad then made it obvious. Right smack in the middle I hit it and put a hole in it the size of a small needle. So I call around for a new one and it's 325$ and some. I pull it out expecting that since it wasn't so new I would see some use but it looks great. I then looked into my local auto parts shop and they had a product called solder-it which is an aluminum soldering paste. I tried it but sadly my rad was still leaking a slight bit. I probably didn't put enough of it or it just didn't adhere properly who knows. Now I am thinking should I bother repairing it or getting a new one? Or even getting a local rad shop a try so they could weld it. I bought some brazing rod I could also try but since I have never done this before the paste was super easy to use but obviously didn't work.
If I do try to fix it myself again I would like to make sure it won't leak again too. I really don't feel like pulling my rad out again lol. So is there any way I can pressure test it?
